Configure the global action to mirror packets that match an access control list (ACL).
The ACL exists.
Configure the global action for an ACL:
Switch:1> enable Switch:1#configure terminal Switch:1(config)#filter acl set 200 global-action monitor-dst-mlt 20
The following table defines parameters for the filter acl set command.
Variable |
Value |
<1-2048> |
Specifies an ACL ID from 1–2048. |
default-action <deny|permit> |
Specifies the global action to take for packets that do not match an ACL. |
global-action {monitor-dst-mlt PT_MLT<1–512>|monitor-dst-ports {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Specifies the global action to take for matching ACLs:
